No, these are two different machines. No upgrad was made.My final solution:I split my script in two parts: If I'm allowed to delete a FeatureClass I use:if arcpy.Exists(__toFCpath):
arcpy.Delete_management(__toFCpath)
arcpy.Copy_management(__fromFCpath, __toFCpath)
And if i'm not allowed to delete a FeatureClass I use:arcpy.DeleteRows_management(...)
arcpy.Append_management(...)
and arcpy.AddIndex_management(...)
to copy the Indexes.But be aware of Bug NIM084818 if you are using ArcGIS 10.2.0 or lower:The Append geoprocessing tool fails to append field values for fields with field names that have 29 or more characters.Cheers.Mickey
