maybe what i really want to know is...what is needed to be installed in a client pc for the custom application made from VS2010 and ArcGIS Engine Developers Kit to run.i have added this in the MyApplication_Startup where the string is generated from License Viewer of Runtime SDK WPF using RUD license code in the same computer where i developArcGISRuntime.SetLicense("")
and added this in LicenseInitializerESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop)
Dim supportedRuntimes() As ProductCode = New ProductCode() {ProductCode.Engine, ProductCode.Desktop}
For Each c As ProductCode In supportedRuntimes
If (RuntimeManager.Bind(c)) Then Return
If (Not ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Engine)) Then
If (Not ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop)) Then
MsgBox("ArcGIS runtime binding failed. Application will shut down.")
End If
End If
i am using 3 machines to test my application where i installed the followingpc 1 - ArcGIS Engine Runtime 10 using the EDN Dev. Kit Licensepc 2 - ArcGIS Desktoppc 3 - ArcGIS Engine Runtime SDK for Javain PC 1 and PC 3 when i run the application i just get a error saying "The Application has stopped working."and in PC 2 got the application running just until a message appear "This control requires an ArcGIS Engine Developer Kit License."maybe its because only Desktop is installed in that machine...and now im stuck...
