Solved! Go to Solution.
<!DOCTYPE HTML> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Home Extent</title> <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <style> html, body, #map { padding:0; margin:0; height:100%; } #HomeButton { position: absolute; top: 95px; left: 20px; z-index: 50; } </style> <script src="//js.arcgis.com/3.9/"></script> <script> require([ "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "esri/dijit/HomeButton", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!" ], function( Map, BasemapGallery, arcgisUtils, HomeButton, parser ) { parser.parse(); var map = new Map("map", { basemap: "topo", center: [-98.185272, 26.282376], zoom: 10 }); var home = new HomeButton({ map: map }, "HomeButton"); home.startup(); var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, map: map }, "basemapGallery"); basemapGallery.startup(); basemapGallery.on("error", function(msg) { console.log("basemap gallery error: ", msg); }); }); </script> </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%;height:100%;margin:0;"> <div id="map" class="map" data-dojo-type="dijit/layout/ContentPane"> <div id="HomeButton"></div> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div data-dojo-type="dijit/TitlePane" data-dojo-props="title:'Switch Basemap', closable:false, open:false"> <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;"> <div id="basemapGallery" ></div></div> </div> </div> </div> </div> </body> </html>
