I keep receiving the following error message when trying to check data back into my geodatabase:
The following ArcPad AXF files were skipped:
Did not contain a transaction log:
(filename).axf
From previous forum questions, this appears to be a problem when you check out a background layer for editing. However, when I am checking out my data I am clearly checking out the data for disconnected editing using my defined extent. I am not checking it out as background data.
I ran a brief test where I checked data out and immediately checked it back in and had no problems. However, when I collect data in the field and try to check it back in later, I get that same frustrating error message. Can anyone help me? I am quickly approaching a busy field season and trying not to panic. Thanks!
