v35322
Clip failure
Discussion created by v35322 on Apr 23, 2014
Latest reply on Apr 24, 2014 by v35322
Hi! I'm attempting to clip a polygon layer from the results of a buffer, and I'm getting error 000117 (Warning empty output generated). Based on some of the results I've found here, I've checked the extents of the layers (not set), checked the coordinate systems of my input layers (identical, GCS WGS 1984), and tried repairing the geometry (the repair geometry tool ran, but I still got the same error afterwards.
I was able to clip the same polygon layer out of a different layer (buffered from the same points but a smaller buffer) without any challenges, but every time I try to clip it out of the layer with the larger buffer I get an error.
Outcomes
