One of my converted VBA tools allows the user to quickly create a custom color ramp for elevation data and bypass the annoyingly long statistics building step when you do the same thing through the layer's property dialog. In my tool, a simple dialog appears in which you select the raster, enter a starting elevation, the number of classes to render, and finally the interval of each class. I use this tool to explore the subtle features found in LIDAR data.Anyways, VBA and dot.net versions of my code USED to work fine whether the data was coming from SDE or a file based raster format (IMG, TIFF, etc). Now the code only works for rasters coming from SDE and I can't seem to understand why this is. Can anyone see what I'm missing in my attached code? This is the code that runs once the user clicks OK: Private Sub OK_Button_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OK_Button.Click
Me.DialogResult = System.Windows.Forms.DialogResult.OK
Dim I As Integer
Dim minElev As Long
Dim numClasses As Integer
Dim theInterval As Double
Dim theRaster As String
Dim curElev As Double
Dim application As ESRI.ArcGIS.Framework.IApplication
Dim pMxDoc As ESRI.ArcGIS.ArcMapUI.IMxDocument
Dim pMap As ESRI.ArcGIS.Carto.IMap
Dim pID As New ESRI.ArcGIS.esriSystem.UID
Dim pEnumLayer As ESRI.ArcGIS.Carto.IEnumLayer
Dim pLayer As ESRI.ArcGIS.Carto.ILayer
Dim pRLayer As ESRI.ArcGIS.Carto.IRasterLayer
Dim pRaster As ESRI.ArcGIS.Geodatabase.IRaster
Dim PMouseCursor As ESRI.ArcGIS.Framework.IMouseCursor
PMouseCursor = New ESRI.ArcGIS.Framework.MouseCursor
PMouseCursor.SetCursor(0)
Try
Application = My.ArcMap.Application
Dim document As ESRI.ArcGIS.Framework.IDocument = Application.Document
pMxDoc = application.Document
pMap = pMxDoc.FocusMap
pID.Value = "{6CA416B1-E160-11D2-9F4E-00C04F6BC78E}"
If String.IsNullOrEmpty(Me.txtStartElev.Text) Or Me.txtStartElev.Text = "" Then
MsgBox("You did not specify a starting elevation.", MsgBoxStyle.Exclamation, "Error")
Exit Sub
End If
If String.IsNullOrEmpty(Me.txtNumLevels.Text) Or Me.txtNumLevels.Text = "" Then
MsgBox("You did not specify the number of classes.", MsgBoxStyle.Exclamation, "Error")
Exit Sub
End If
If String.IsNullOrEmpty(Me.cboInterval.Text) Or Me.cboInterval.Text = "" Then
MsgBox("You did not specify the interval.", MsgBoxStyle.Exclamation, "Error")
Exit Sub
End If
minElev = CInt(Me.txtStartElev.Text)
numClasses = CInt(Me.txtNumLevels.Text)
theInterval = CDbl(Me.cboInterval.Text)
theRaster = Me.cboRasterLyr.Text
curElev = minElev
pEnumLayer = pMap.Layers(pID, True)
pEnumLayer.Reset()
pRLayer = Nothing
pLayer = pEnumLayer.Next
Do While Not pLayer Is Nothing
If TypeOf pLayer Is ESRI.ArcGIS.Carto.IRasterLayer Then
If StrComp(pLayer.Name, theRaster, vbTextCompare) = 0 Then
pRLayer = pLayer
End If
End If
Loop
If TypeOf pRLayer.Renderer Is ESRI.ArcGIS.Carto.IRasterStretchColorRampRenderer Then
Dim question, answer
question = "It may take a long time in order to change this raster's" & vbNewLine
question = question & "symbology. Are you sure you would like to continue?" & vbNewLine
answer = MsgBox(question, MsgBoxStyle.YesNo, "WARNING!")
If answer = vbNo Then
Exit Sub
End If
End If
'Create classfy renderer and QI RasterRenderer interface
pRaster = pRLayer.Raster
Dim pClassRen As ESRI.ArcGIS.Carto.IRasterClassifyColorRampRenderer
pClassRen = New ESRI.ArcGIS.Carto.RasterClassifyColorRampRenderer
Dim pRasRen As ESRI.ArcGIS.Carto.IRasterRenderer
pRasRen = pClassRen
'These simple three lines is all you need in order to change the color ramp
'that is used. They do need to exist shortly after pClassRen is initialized
'otherwise the specification is ignored..
Dim pClassProp As ESRI.ArcGIS.Carto.IRasterClassifyUIProperties
pClassProp = pClassRen
pClassProp.ColorRamp = "Temperature" 'Name of Ramp from Style Manager
'Set raster for the render and update
pRasRen.Raster = pRaster
pClassRen.ClassCount = numClasses
pRasRen.ResamplingType = ESRI.ArcGIS.Geodatabase.rstResamplingTypes.RSP_BilinearInterpolation 'Set to Bilinear Interpretation
pRasRen.Update() 'THIS IS WHERE THE CODE CRASHES
'loop through the classes and update the label
For I = 0 To pClassRen.ClassCount - 1
pClassRen.Break(I) = curElev
Select Case I
Case 0
pClassRen.Label(I) = "< " & CStr(curElev) & " Feet"
Case pClassRen.ClassCount - 1
pClassRen.Label(I) = "> " & CStr(curElev) & " Feet"
Case Else
pClassRen.Label(I) = CStr(curElev) & " - " & CStr(curElev + theInterval)
End Select
curElev = curElev + theInterval
Next I
'Update the renderer and plug into layer
pRasRen.Update()
pRLayer.Renderer = pClassRen
pMxDoc.ActiveView.Refresh()
pMxDoc.UpdateContents()
'Release memeory
pMxDoc = Nothing
pMap = Nothing
pRLayer = Nothing
pRaster = Nothing
pRasRen = Nothing
pClassRen = Nothing
pClassProp = Nothing
Me.Close()
Catch ex As Exception
globalErrorHandler(ex)
End Try
End Sub
The error handler returns the following when it crashes:ERROR DESCRIPTION: Error HRESULT E_FAIL has been returned from a call to a COM component.
TYPE OF ERROR: System.Runtime.InteropServices.COMException
STACK TRACE: at ESRI.ArcGIS.Carto.RasterClassifyColorRampRendererClass.Update()
at pwTools2.frmAdjustColorramp.OK_Button_Click(Object sender, EventArgs e) in C:\Visual Studio 2008\Projects\pwTools2\pwTools2\frmAdjustColorramp.vb:line 105
Any ideas? THANKS!Steve
