Re: Dissolve Error 999999 Invalid Topology Out of memory
8434
07-20-2010 09:18 AM
JoeChampagne
This post is in response to the archived thread:
http://forums.esri.com/thread.asp?t=289514&f=983&c=93
regarding the following error message, received while attempting to Dissolve a dataset:
"ERROR 999999: Error executing function.
Invalid Topology [Out of memory.]
Failed to execute (Dissolve)."
This may be a dead issue, but I'm posting in case anyone is still having trouble with this. I received this message while attempting to Clip a relatively small dataset to polygon study area boundaries. I was able to run the tool successfully by moving my input layers to a new map document before running 'Clip'.
This leads me to suspect the issue here isn't related to machine performance but rather some geoprocessing environment setting, probably temp/scratch workspace directories. I wasn't able to track down the offending setting, but hopefully this workaround will help someone!
MatthewFoster2
Thank you very much!  This solved my problem when i was receiving this error on a dissolve
SarahWhite2
Thank you so much! I've been struggling with this one all day on a very small dataset. I was starting to doubt my GIS carreer prospects!
BryanFerri1
In case anyone out there is banging their head against the wall about this...
  - I spent an hour+ looking over these threads trying to resolve a related issue - I tried to dissolve a layer with tonnns of "slivers" resulting from a union. Result was an "empty output". I tried "repair geometry", it succeeded per results window, so I tried again, same result = "empty output". I noticed the repair tool still showed many fixed features if I ran it again. I then noticed it was only fixing some of my features (was a big file - 60K polygons). I ran it several more times until there were no more to repair, tried dissolve again, and it worked. Oy! Hope this helps.
DruSexton1
This worked for me in Pro, and I only needed run the process 1 time, it seemed to resolve numerous errors. I also ran this on a Parcel layer with just under 60k parcels. Thanks for the tip!
