bives
Attribute Inspector for Points editing
Discussion created by bives on Apr 22, 2014
Latest reply on Aug 8, 2014 by weandjlw
I am attempting to get an application working where editors can click on a point feature and edit a form. I need the form to have a save button that when clicked will apply the edits to the feature.
I am selecting the point/s using an envelope. Is there a way I can tell what feature I need to apply the edits to on my save click event? I would like to store the edits to a feature as fields are changed and then only save the edits to the feature class with the save button.
I am trying to use this example to understand the edit saving and then the feature save. Attribute Inspector
Here is what I am working with right now. I am grabbing the point features within an envelope:
function initEditor() {
          var featureLayer = layersFS[1].layer;
      var selectQuery = new Query();
      map.on("click", function (evt) {
          var centerPoint = new esri.geometry.Point
           (evt.mapPoint.x, evt.mapPoint.y, evt.mapPoint.spatialReference);
          var mapWidth = map.extent.getWidth();
          //Divide width in map units by width in pixels
          var pixelWidth = mapWidth / map.width;
          //Calculate a 10 pixel envelope width (5 pixel tolerance on each side)
          var tolerance = 10 * pixelWidth;
          //build query filter
          query = new esri.tasks.Query();
          query.returnGeometry = true;
          query.outFields = ["*"];
          //Build tolerance envelope and set it as the query geometry
          var queryExtent = new esri.geometry.Extent
                  (1, 1, tolerance, tolerance, evt.mapPoint.spatialReference);
          query.geometry = queryExtent.centerAt(centerPoint);
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
              if (features.length > 0) {
                  //store the current feature
                  for (var i = 0; i < features.length; i++) {
                      updateFeatures.push(features[i]);
                  //map.infoWindow.setTitle(features[0].getLayer().name);
                  map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
              } else {
                  map.infoWindow.hide();
Then I am planning to update the specific feature with the save button:
saveButton.on("click", function () {
          //need to figure out how to get the current feature with the save click,
          //the envelope may return 1 to many records and I need the current feature
          updateFeatures.forEach(function(entry) {
          updateFeature.getLayer().applyEdits(null, [updateFeature], null);
      ///////Need to apply similar logic as save button click but this will update the current feature in the updateFeatures[]
      attInspector.on("attribute-change", function (evt) {
          //store the updates to apply when the save button is clicked
          updateFeature.attributes[evt.fieldName] = evt.fieldValue;
What is the best way to determine what my current feature is in the info window that is being edited?
Thanks for any advice!
Outcomes
