JSON to Graphic to Map
2286
04-17-2014 01:39 PM
NathanDorman
Hey guys,
I was wondering if the documentation on website API is up to date or if I'm just missing something. I'm trying to add a graphic to my map by creating a graphic using JSON by the format and parameters stated in the API.
validation checked w/ jsonlint.com
var json = {"geometry":{"points":[[608647.8,2368271.8],[608252.7,2368339.2],[600298.56,2384759.5],[598867.1,2384862],[597231.44,2384743.2],[599478.1,2384728.8],[598811.1,2384355.5],[599798.75,2384646.2],[600041.44,2384662.5],[598171.25,2389613.5],[598431.3,2389301],[595302.94,2388870],[600176.1,2375361.8],[599342.7,2382036.5],[594301.56,2382029.8],[603859.9,2381974],[594440.3,2382028.8],[602758.9,2381808.2],[594808.5,2381696.8],[599076.9,2377178.8]],"spatialReference":{"wkid":26904,"latestWkid":26904}},"symbol":{"color":[120,255,120,64],"size":20,"angle":0,"xoffset":0,"yoffset":0,"type":"esriSMS","style":"esriSMSX","outline":{"color":[0,0,0,255],"width":5,"type":"esriSLS","style":"esriSLSSolid"}}}
var graphic = new Graphic(json);
// This doesn't work
map.getLayers("graphicsLayer").add(graphic);
/* this also doesn't work
map.graphics.add(graphic);
// I also call graphic.toJson() and console.log(map) to check their validity
When I inspect the HTML, I do see that the graphics layer element under "#content_layers > svg >" g does exist and just contains:
<g id="series_layer" transform="matrix(1.00000000,0.00000000,0.00000000,1.00000000,25.00000000,85.00000000)" style="display: block;"><g></g></g>
I thought it might be an ordering issue, but I made my only dynamic map layer transparent, which had no effect.
I also checked to make sure that map was not undefined, and I'm sure that all my references do exist.
I'm on JS API v3.8 and did try 3.9.
Any suggestions? I feel like I'm close, but can't figure it out.
JonathanUihlein
You are close!
Here's a sample using different points, but the same symbol.
http://jsfiddle.net/tE4A3/8/
If your graphic still doesn't draw, you may end up having to convert those points to wkid 102100 or 4326.
JonathanUihlein
You are close!
NathanDorman
Thanks for the reply. It's good to see some working sample of a graphic created by JSON. But your point about projection might be the solution to my problem. I still can't seem to render the graphic.
will calling
point.setSaptialReference({ "wkid": 4326 });
resolve the spatial reference issue and update my x and y coordinates?
NathanDorman
Thanks Jon, I ended up having to change the spatialreference of all my data (I was thinking of reprojecting using JS).
