Sobel edge detection
1026
7
04-17-2014 07:42 AM
MaherAL_ZUHAIRI
Can anybody tell what is wrong with this:
it works in python window, but when I make it script tool does not work
please help
import scipy.ndimage
import numpy,arcpy
import string
import PIL.Image
inpRaster=arcpy.GetParameterAsText(0)
desc = arcpy.Describe(inpRaster)
layersource = desc.catalogPath
imageread=scipy.ndimage.imread(layersource)
sobelimage=scipy.ndimage.sobel(imageread,0)
outimage=PIL.Image.fromarray(sobelimage)
Out=outimage.save('D:\Outputs\sobel.jpg')
DanPatterson_Retired
what is the error message?
MaherAL_ZUHAIRI
No error message, just after click OK to execute the text file open (Code file).........
GerryGabrisch
Occasional Contributor III
Try running this version with an error handler and see if you get an error message to post.
# NeighborScore.py
# Created on: 2013-01-07 13:26:35.00000
# Updated on: 2014-02-12
# Description: Will create output tables based on the average and sum of neighboring polygon values
#B comment: I believe this is as the script was delivered on Feb 12 2014
#B comment: See most recent NeighborScore_Working version for most current version
try:
    import sys
    import traceback
    import numpy,arcpy
    import string
    import PIL.Image
except arcpy.ExecuteError:
    print "error"
    msgs = arcpy.GetMessages(2)
    arcpy.AddError(msgs)
    print msgs
except:
    print "error"
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback info:\n" + tbinfo + "\nError Info:\n" + str(sys.exc_info()[1])
    msgs = "ArcPy ERRORS:\n" + arcpy.GetMessages(2) + "\n"
    arcpy.AddError(pymsg)
    print pymsg + "\n"
    print msgs
MaherAL_ZUHAIRI
# NeighborScore.py
try:
    import sys
    import traceback
    import numpy,arcpy
    import string
    import PIL.Image
    print "error"
    print msgs
except:
    print "error"
    print pymsg + "\n"
    print msgs
error
PYTHON ERRORS:
Traceback info:
  File "<string>", line 23, in <module>
Error Info:
"" does not exist
ArcPy ERRORS:
MaherAL_ZUHAIRI
The error message because the function GetParameterAsText(0), so I used raster data instead , the error message has gone .
in other words, no error message in the code, but the problem I think is in the output function. the code is executed but the save function does not apply.
try r'D:\Outputs\sobel.jpg'  for the filename
MaherAL_ZUHAIRI
Same problem, can I convert the image into raster using RasterCopy Management. so may be that image will be saved.
if it is possible how can I do it.
