AnsweredAssumed Answered
Simple CSV Question
Question asked by FLBB on Apr 16, 2014
Latest reply on Apr 17, 2014 by FLBB
I have a script that currently writes to txt and doc files that I want to be able to write to a csv..
import arcpy import os  #Initialize Parameters, Set workspace parameters, and intermediate processing files  lstfc = arcpy.GetParameterAsText(0).split(";") output = arcpy.GetParameterAsText(1) arcpy.env.workspace = "in_memory" arcpy.env.overwriteOutput = True animals=['dog','cat','turtle','giraffe'] fcjoin=path to join features outfile = "in_memory\\sptjn"  # Open writing file, Begin iterating through feature class(es) supplied by user  with open(output,'w') as f:     f.write("Missing Animals By Zoo"+" "+ '\n'+'\n'+'\n')     for fc in lstfc:         f.write("       "+"************************************************"+'\n'+'\n')         totalcount=int(arcpy.GetCount_management(fc).getOutput(0))  # If the attribute field Zoo exists and the number of unique values in ZOO equals the total number of all animals write the information              if arcpy.ListFields(fc,"ZOO") and len(set([row.getValue("ZOO") for row in arcpy.SearchCursor(fc,"ZOO<>'' AND ZOO IS NOT NULL")]))==len(animals) :             f.write("   "+"Feature Class: "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')             f.write("       "+"There are currently no missing animals in"+" "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')  # If there are no features in the supplied featureclass write the following                 elif totalcount==0:             f.write("   "+"Feature Class: "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')             f.write("       "+"There are currently no features" +" "+ "in"+" "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')  # If the attribute field ZOO exists, and if animal in the list is not in the featue class write the following          elif arcpy.ListFields(fc,"ZOO"):             f.write("   "+"Feature Class: "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')             myList=set([row.getValue("ZOO") for row in arcpy.SearchCursor(fc,"ZOO<>'' AND ZOO IS NOT NULL")])             for animal in animals:                 if animal not in myList:                     f.write("           "+animal+'\n'+'\n')  # If the attribute field Zoo does not exist, perform a spatial join to the join features, create field map, then if the animal in the list is not in the feature class write the following           elif not arcpy.ListFields(fc,"ZOO"):             f.write("   "+"Feature Class: "+str(os.path.basename(fc)).split('.')[2]+'\n'+'\n')             fieldmappings = arcpy.FieldMappings()             fieldadmu = arcpy.FieldMap()             fieldadmu.addInputField(fcjoin,"ZOO")             fieldmappings.addFieldMap(fieldadmu)             arcpy.SpatialJoin_analysis(fc,fcjoin,outfile, "#", "#", fieldmappings)             intlist=set([row.getValue("ZOO") for row in arcpy.SearchCursor(outfile,"ZOO<>'' AND ZOO IS NOT NULL")])             for animal in animals:                 if animal not in intlist:                     f.write("           "+animal+'\n'+'\n')      arcpy.Delete_management("in_memory")
I need a column for "Feature Class" and a column for "Animals". Under feature class i want to list the feature class and next to it I want to capture the missing animal(s) under the Animals column. I have commented the code for your convenience. Any input would be appreciated. Thanks!
Outcomes
