sbrockwell
ArcSDE C-API SE_stream_calculate_table_statistics() crash with Oracle
Discussion created by sbrockwell on Apr 16, 2014
Latest reply on Apr 24, 2014 by sbrockwell
I'm maintaing an ArcSDE client application which apparently was working with ArcSDE 9.1
Current configuration: ArcSDE 10.1 with Oracle 10.1, Win 7 x32/x64
Symptoms when calling SE_stream_calculate_table_statistics() with SE_DISTINCT_STATS as mask on a STRING property:
   1. crashes with SE_NET_FAILURE (-10)
   2. memory violation when using direct connect in sdeora11gsrvr101.dll
   3. Works fine with numerial properties (integer/double)
   4. Works fine with SqlServer with any property type (integer/double/string)
Note: 2) and 3) prove the code is correct.
Any information greatly appreciated. Thanks in advance.
Outcomes
