i use IHitTest to get distance, a point has z value hittest a polyline has z value ,but the result distance just computed via x and y value,does not use z to do hitttest. how to hittest use z value.thanks
I don't believe there is a way through ArcObjects to do a 3D hit test but if you just want to get the distance between two geometries you can use IProximityOperator3D.
