Target must be an event emitter
4003
11
04-15-2014 10:23 AM
MattTenold
New Contributor III
I am currently using the Dojo/on and I keep receiving the Error: Target must be an event emitter
http://js.arcgis.com/3.9/
Line 212
error in this function:
function runQuery() {
   var queryTask = new esri.tasks.QueryTask("http://gis.phila.gov/ArcGIS/rest/services/PhilaGov/Police_Incidents_Last30/MapServer/0");
   var query = new esri.tasks.Query();
   query.returnGeometry = true;
   query.where = '1=1';
   query.outFields = ["DC_DIST", "POINT_X", "POINT_Y"];
   map.on(queryTask, "onComplete", function(featureSet) {
    var cL = new clusterlayerNew({
     displayOnPan: false,
     map: map,
     features: featureSet.features,
     infoWindow: {
      template: new esri.InfoTemplate("${SECTOR}"),
      width: 325,
      height: 100
     flareLimit: 15,
     flareDistanceFromCenter: 20
             map.addLayer(cL);
DasaPaddock
Try: queryTask.on("complete", function(event) {});
See:
https://developers.arcgis.com/javascript/jsapi/querytask-amd.html#event-complete
MattTenold
New Contributor III
I can't do
since I am constructing a clusterlayer using the function features from my AMD class "clusterlayerNew."   Is there a way to get the features from the function "features" while running after the  queryTask is complete?
ReneRubalcava
How about
on(queryTask, 'complete', function(){});
You lost me there, but the execute method returns a Promise, so you can also do.
queryTask.execute(query).then(someFunction);
DasaPaddock
How about this?
      map: map,
      features: event.featureSet.features,
      infoWindow: {
        width: 325,
        height: 100
      flareLimit: 15,
    map.addLayer(cL);
MattTenold
New Contributor III
I tried both methods.  But this won't work either.  The main problem is all of my events are handled in my Dojo class.  I attached the main html page and the dojo class with the logic that the main page accesses.
     map: map,
     infoWindow: {
      width: 325,
      height: 100
     flareLimit: 15,
             map.addLayer(cL);
DasaPaddock
I just noticed that `runQuery` is missing a call to `queryTask.execute(query)`. Can you try adding this before the queryTask.on line?
MattTenold
New Contributor III
Tried that also.  Didn't work.  It keeps saying Target must be an event emitter.
DasaPaddock
Is this code still in the html page?
  on(queryTask, "onError", function(err) {
  alert(err.details);
  queryTask.execute(query);
Can you remove it since outside the runQuery function, queryTask is the esri/tasks/QueryTask module rather than an instance of a QueryTask.
MattTenold
New Contributor III
Tried that.  It runs but it keeps jumping around.  It doesn't go through the functions.  It is really weird.  I set a break point but it won't step through the functions.  I am still looking for why it doesn't continue running through the functions.
