pltsltesri
Remove a rule from a shape
Discussion created by pltsltesri on Apr 15, 2014
Latest reply on Apr 16, 2014 by MBuehler-esristaff
I find that once I apply a rule that the shape somehow remembers the setting in the rule even if I delete the "Rule File" entry in the inspector and then re-apply the rule or even another rule. For instance if I apply a rule and change the attribute that controls the level of detail to high, then delete the rule from the "Rule File" entry in the inspector, if I apply the same rule again, or another rule tat uses the same level of detail attribute, the building that is created has the same level of detail tha the original did. Is this how it is supposed to work? Is there a way to remove all remnants of the rule from a shape so you are essentuially starting with a blank slate?
Outcomes
