Coded Value Domain in the REST API
875
04-14-2014 10:01 AM
GhassanKarwchan
New Contributor III
Can you have the map service expose the coded domain values defined for the columns with the code, on the rest api, so we can view the values when we do query, or we can query on the coded domain value instead of the code?
thanks
RichardFisher
New Contributor III
I have the same issue and in addition, there is a 'queryDomains' rest services link that wants a "Layers:" input only, yet no layer value such as 2, or layers=all,2 or similar formats work only format error returned. Basically need the REST api to return the value and not just the code in some cases.
