Can't Add Feature Off-Line
518
04-14-2014 08:59 AM
JasonGraf
I just downloaded close to 400MB after selecting my work area and details required.
The map loads, but there is no "+" button to add features.  I can select, edit, and synch other existing features.
I'm on a Motorola 4G tablet, Droid 4.0 OS.
I downloaded the same map (smaller extent) to my iPhone and it works fine.
Thoughts?
Jay
RussRoberts
Esri Notable Contributor
On the tablet there should be a panel on the right hand side of the screen with all collectable features. Do you see that panel there on a connected version of the map?
Russ
JasonGraf
Yes, the app works as expected on line. I can see and use the panel on the right hand side.
Jason
RussRoberts
The feature service may not be showing up offline because the feature service may have fields that are SQL reserved and that could be causing the issue. If I can take a look at the map and service I will be able to tell.
Russ
