Dollar symbol on ArcGIS Online
6344
04-08-2014 10:29 AM
JacobFrie
Hello, I've constructed an attribute field called "price" within a shapefile on my ArcGIS 10.1 for Desktop. I will be using the information in that shapefile to create an ArcGIS Online Map that can show the prices of parcels of land for purchase. The problem is, I can't figure out how to get the dollar sign to show up in the pop-up box on ArcGIS Online (i.e., $7,400.00). I can get the comma separator, but no dollar symbol (i.e., 7,400.00). Anybody know how to get that to show up? Thanks!
~ Jake
EldredAllen
When you 'Configure Pop-up' in AGO, under the 'Pop-up Contents' you have an option to Display A custom attribute display.  Once you have that option selected you click the large green 'Configure Button' and you can configure the way your pop-up looks.  Along the top ribbon at the far right of the Custom Attribute Display window there is a '+' button and you can use this to see what attributes you have in your shapefile.  So to create your custom pop-up you can write:
price = $ {price}
parcel = {parcel} - this is an example
And then add what other attributes you want in your pop-up as well below this one.  And as I mentioned, to include the other attributes just use the '+' button so you don't have to remember what all of your attributes are.
I hope this helps.
DavidTowsey1
I know this is an old post, but I just got to start playing around with ArcGIS Online and this is tremendously helpful to me. Thank you so much.
JacobFrie
price = $ {price}
I hope this helps.
Thank you very much for your help. I will give this a try. These forums are awesome!
~ Jake
JarrettGreen
New Contributor III
So bringing this thread back...
I like the workflow, however is it possible to use the styling of the stock pop-ups? For my parcel layer, I simply want to add a $ sign before any monetary values, but would like the style of this pop-up to match all the others.
I see the ‘View HTML Source’ but I am not well-versed in HTML and CSS enough to craft it.  Has anyone attempted this before?
Jarrett
