Converting Image KMZ to projected raster
2429
04-03-2014 01:35 AM
HuongPhan
Hi all,
I am using Arcgis 10. I have a KMZ file of an image. How can I convert it to projected raster? (my friend can do it with tool "COnversion-> KML to Layer, but he is using Arcgis 10.1).
(I save it as KML, and then try to project the image generated, but it go to wrong location).
Huong
IanMurray
When you bring the kml in does it have a projection?  If it doesn't you can simply georeference it using the georeference toolbar.
markdenil
Occasional Contributor III
kml only supports lat/long (geographic) coordinates.
Once you pry it out of the kml, that is what it should be,
so just try defining the raster projection as
GCS_WGS_1984
WKID: 4326 Authority: EPSG
