AnsweredAssumed Answered
Failed on input OID
Question asked by Tonyalmeida on Apr 1, 2014
Latest reply on Apr 3, 2014 by AdamCox
I have a layer in my TOC that has a joined table. When i run the following code it get Failed on input OID.  I believe it is because the layer "vector.DBO.Taxparcels" has a table joined but i am not sur.? According to the Arcgis help on ERROR 001156 it's because text values cannot be added to numeric fields, and text values cannot be added to text fields if the values are longer than the field length.The Solution Change the field type or increase the field length in the field map properties. I a not sure why I am getting an error on arcpy.MakeFeatureLayer_management(PL_Lyr, PL_Lyr2)?
Code:
####Select by location on parcels with created point Parcellyr = "vector.DBO.Taxparcels"  arcpy.MakeFeatureLayer_management(Parcellyr, "Parcel layer") entries = int(arcpy.GetCount_management(fc).getOutput(0))  for i in xrange(entries):     Sel_Point = arcpy.MakeFeatureLayer_management(fc, "point layer", "\"FID\"={}".format(str(i))) #FID     arcpy.SelectLayerByLocation_management("Parcel layer", "INTERSECT", Sel_Point, "", "NEW_SELECTION")  #### populates fields  add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","predir","StreetType","SubName"]  # fix args if not isinstance(add_fields, list):     # from script tool     add_fields = add_fields.split(';')  # do not need this scratch file fcOutput = "temp_join" arcpy.SpatialJoin_analysis("Parcel layer", fc, fcOutput, 'JOIN_ONE_TO_MANY')   # grab oid field from points oid_t = arcpy.Describe(fc).OIDFieldName  # init rowW and rowR curR = arcpy.SearchCursor(fcOutput) join_dict = dict([(r.JOIN_FID,[r.getValue(f) for f in add_fields]) for r in curR]) del curR  # Now update the new target curW = arcpy.UpdateCursor(fc) for row in curW:     t_oid = row.getValue(oid_t)     if t_oid in join_dict:         for f in add_fields:             row.setValue(f, join_dict[t_oid][add_fields.index(f)])     curW.updateRow(row) del row, curW  arcpy.Delete_management("Parcel layer")
Error:
Traceback (most recent call last):   File "C:\GIS\Python Scripts\AddressPoints\Select by Location based on selected features_3a.py", line 61, in <module>     arcpy.SpatialJoin_analysis("Parcel layer", fc, fcOutput, 'JOIN_ONE_TO_MANY')   File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\analysis.py", line 480, in SpatialJoin     raise e ExecuteError: ERROR 001156: Failed on input OID 387502, could not write value 'LN      ' to output field StreetType_1 Failed to execute (SpatialJoin).
I have the following code with field mapping but i am getting an error.
Code:
####Select by location on parcels with created point Parcellyr = "vector.DBO.Taxparcels"  ParLyr = arcpy.MakeFeatureLayer_management(Parcellyr, "Parcel layer") entries = int(arcpy.GetCount_management(fc).getOutput(0))  for i in xrange(entries):     Sel_Point = arcpy.MakeFeatureLayer_management(fc, "point layer", "\"FID\"={}".format(str(i) + ""))     PL_Lyr = arcpy.SelectLayerByLocation_management(ParLyr, "INTERSECT", Sel_Point, "", "NEW_SELECTION")     #if arcpy.Exists(pt_lyr): arcpy.Delete_management(pt_lyr)  Sel_PT = "Sel_PTT" arcpy.MakeFeatureLayer_management(Sel_Point, Sel_PT) PL_Lyr2 = "PL_Layer" arcpy.MakeFeatureLayer_management(PL_Lyr, PL_Lyr2)  fcOutput = r"C:\Temp\default.gdb\temp_join"   #Field Mapping def Layers(PL_Lyr2, Sel_PT):     FieldMapString = "" \                 + """ACCOUNT "ACCOUNT" true true false 11 Text 0 0 ,First,#,""" + PL_Lyr2 + """,ACCOUNT,-1,-1;"""\                 + """SiteNum "SiteNum" true true false 10 Double 0 0 ,First,#,""" + PL_Lyr2 + """,SiteNum,-1,-1;"""\                 + """OwnerName "OwnerName" true true false 100 Text 0 0 ,First,#,""" + PL_Lyr2 + """,OwnerName,-1,-1;"""\                 + """SiteAddress "SiteAddress" true true false 106 Text 0 0 ,First,#,""" + PL_Lyr2 + """,SiteAddress,-1,-1;"""\                 + """SiteNumSfx "SiteNumSfx" true true false 6 Text 0 0 ,First,#,""" + PL_Lyr2 + """,SiteNumSfx,-1,-1;"""\                 + """SiteStreet "SiteStreet" true true false 64 Text 0 0 ,First,#,""" + PL_Lyr2 + """,SiteStreet,-1,-1;"""\                 + """Predir "Predir" true true false 2 Text 0 0 ,First,#,""" + PL_Lyr2 + """,Predir,-1,-1;"""\                 + """StreetType "StreetType" true true false 8 Text 0 0 ,First,#,""" + PL_Lyr2+ """,StreetType,-1,-1;"""\                 + """SubName "SubName" true true false 20 Text 0 0 ,First,#,""" + PL_Lyr2 + """,SubName,-1,-1;"""\       fieldmappings = arcpy.FieldMappings()     fieldmappings.loadFromString(FieldMapString)     return fieldmappings  def main(args=None):         if args is None:                 args = sys.argv  arcpy.SpatialJoin_analysis(PL_Lyr2, Sel_PT, fcOutput,                            "JOIN_ONE_TO_MANY", "KEEP_ALL", Layers(PL_Lyr2, Sel_PT), "INTERSECT")  #### populates fields  add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","Predir","StreetType","SubName"]  # fix args if not isinstance(add_fields, list):     # from script tool     add_fields = add_fields.split(';') # do not need this scratch file #fcOutput = "temp_join" #'temp_join' when using workspace = r"C:\Temp\default.gdb" #arcpy.SpatialJoin_analysis("Parcel layer", fc, fcOutput, 'JOIN_ONE_TO_MANY')  # grab oid field from points oid_t = arcpy.Describe(fc).OIDFieldName  # init rowW and rowR curR = arcpy.SearchCursor(fcOutput) join_dict = dict([(r.JOIN_FID,[r.getValue(f) for f in add_fields]) for r in curR]) del curR  # Now update the new target curW = arcpy.UpdateCursor(fc) for row in curW:     t_oid = row.getValue(oid_t)     if t_oid in join_dict:         for f in add_fields:             row.setValue(f, join_dict[t_oid][add_fields.index(f)])     curW.updateRow(row) del row, curW
Error with filed mapping:
Traceback (most recent call last):   File "C:\GIS\Python Scripts\AddressPoints\Create_Point_2_a.py", line 66, in <module>     arcpy.MakeFeatureLayer_management(PL_Lyr, PL_Lyr2)   File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 5748, in MakeFeatureLayer     raise e ExecuteError: ERROR 999999: Error executing function. The table does not have an OID Field. Failed to execute (MakeFeatureLayer).
Outcomes
