Solved! Go to Solution.
I think I understand the problem.
Can you try moving the swipe domNode into the map domnode? After the widget is loaded probably.
Currenlty, the widget gets placed into the layers div but I think that is causing the hover issue.
Like this:domConstruct.place(mySwipeWidget.domNode, dom.byId('my_map_id'), 'last');
_init: function() { // set type of swipe this._setSwipeType(); // events this._setupEvents(); // check if not enabled this._enabled(); // we're ready this.set("loaded", true); this.emit("load", {}); // giddyup this.swipe(); },
