landsmike
Problem caused by single tap on MapView in SDK 10.2.2
Discussion created by landsmike on Mar 25, 2014
Latest reply on May 26, 2014 by landsmike
We encountered a problem in SDK 10.2.2:
After a MapView is received more than 2 single tap events, the base map (or the dynamic layer) will not be updated when we change the map scale programatically (e.g. MapView.zoomin() / zoomout() / zoomToScale() / etc.)
The only way to refresh the MapView is to do a pan or pinch manually.
The following code is for regenerating the problem. Basically, it creates a MapView, and do a "MapView.zoomin()" when OnSingleTap event is detected. You can do the following:
1) Perform a single tap on the MapView
2) Wait for 2 seconds
3) Perform a single tap on the MapView
4) Wait for 2 seconds
You will see the map is zooming in, but the base tiles will not refresh.
package com.esri.arcgis.android.samples.helloworld;
import android.app.Activity;
import android.os.Bundle;
import com.esri.android.map.MapView;
import com.esri.android.map.ags.ArcGISTiledMapServiceLayer;
import com.esri.android.map.event.OnSingleTapListener;
public class HelloWorld extends Activity {
MapView mMapView = null;
ArcGISTiledMapServiceLayer tileLayer;
@Override
public void onCreate(Bundle savedInstanceState) {
  super.onCreate(savedInstanceState);
  setContentView(R.layout.main);
  mMapView = (MapView) findViewById(R.id.map);
  tileLayer = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
  mMapView.addLayer(tileLayer);
  mMapView.setOnSingleTapListener(new OnSingleTapListener() {
   private static final long serialVersionUID = 1L;
   @Override
   public void onSingleTap(float x, float y) {
    mMapView.zoomin();
@Override
protected void onPause() {
  super.onPause();
  mMapView.pause();
@Override
protected void onResume() {
  super.onResume();
  mMapView.unpause();
Outcomes
