Error: Machine: xxx.xxx.com [MyDataSourceTitle: The connection property set was missing a required property or the property value was unrecognized. Version not found ["Domain\arcgisserver".Domain\arcgisserver]]
Solved! Go to Solution.
SERVER=MyServer;INSTANCE=sde:sqlserver:MyServer;DBCLIENT=sqlserver;DB_CONNECTION_PROPERTIES=MyServer;DATABASE=MyDatabase;USER=MyUsername;VERSION=Domain\OwnerName;AUTHENTICATION_MODE=DBMS
SERVER=MyServer;INSTANCE=sde:sqlserver:MyServer;DBCLIENT=sqlserver;DB_CONNECTION_PROPERTIES=MyServer;DATABASE=MyDatabase;VERSION=CustomUserName.VersionName;AUTHENTICATION_MODE=OSA
