AnsweredAssumed Answered
ArcGISDynamicMapServiceLayer LayerDefinitions 10.0 to 10.2
Question asked by JSim on Mar 20, 2014
Latest reply on Mar 31, 2014 by jeff.pace
We are currently upgrading from a 10.0 to a 10.2 server and are having issues with one of our apps built in JavaScript. The JavaScript API is generating an export map call with layer definitions setup like:
6:(USERNAME = 'test');7:(USERNAME = 'test')
Which works fine in 10.0 but fails in 10.2. I looked at examples in the documents and found one here which shows that the request should be sent with the parameter like:
{6:(USERNAME = 'test'),7:(USERNAME = 'test')}
Note that it is wrapped in curly braces and layers are separated by commas instead of semi-colons.
To setup these definitions in the code all I did was (not the exact code):
var definitions = []; definitions[6] = '(USERNAME = 'test')'; definitions[7] = '(USERNAME = 'test')';  service.setLayerDefinitions(definitions);
Anybody have any thoughts on what I might be doing wrong or if this could be a bug in the api?
NOTE: 10.0 api works with commas instead of semi-colons but fails when wrapped with curly braces. 10.2 only works with semi-colons and must be wrapped with curly braces
- Jamie
Outcomes
