default label field
400
03-20-2014 10:49 AM
LindaCollins
How do you change the default field for labels in model builder?
WilliamCraft
MVP Regular Contributor
I believe the Display Field that ArcMap determines to be the default is based on this sequential logic:
  1. First field of type Text whose name contains the word "name" (case-insensitive)
  2. First field of type Text
  3. First field of an integer type
  4. First field of any type
I think the label field ends up being whatever the Display Field ends up being.  So are you asking how to set the Display Field for a particular layer within ArcMap?  What is the reason for wanting to change a label field in Model Builder?  I'm not sure if that can be set using Model Builder, and after looking at the arcpy capabilities for layers within a map document I'm almost certain you can't set this even through a stand-alone Python script.
