Is there any way to manipulate the JSON or format of data before you push it to a external website? Or control which fields? Or will I have to do a Field reducer or enricher and put it into another service before i send it to the output?
What about building JSON output in a way that it contains nested attributes? I need to produce output which 'push JSON to an External Website' and the group structure of JSON is required. I tried to build a new definition and use Field Mapper to map non-group fields into group fields but then GeoEvent Service stopped counting outputs. I found similar issue but there was no solution (Mapping non-group fields into Group fields using Field mapper ). Is there any way to achieve it?
Best, Aleksandra
I'm not sure I understand when you say "and put it into another service before i send it to the output" ...
You should be able to include as many processors -- Field Reducer, Field Calculator, Field Enricher, etc. -- in-line to manage an event's fields, calculate new (or update existing) fields, and enrich events with data prior to sending then to an Output. There's only one GeoEvent Service in play; you shouldn't need another service to do what you are trying to do.
Keep in mind that an Input receives event data as a byte-stream and is responsible for constructing a GeoEvent. The GeoEvent is the object being processed by the GeoEvent Service. If, for example, you do not want a recipient to see certain fields in the JSON they receive, you need to use either a Field Reducer to remove those fields from the GeoEvent or a Field Mapper to map the GeoEvent to a target output schema.
The GeoEvent Service is not going to "manipulate the JSON or format of data". The Output will receive a processed GeoEvent and deconstructing it to build a JSON representation before sending the event data as JSON to the external website.
- RJ
