gprocino
minimal privileges to sde user after geodb creation
Discussion created by gprocino on Mar 20, 2014
Latest reply on Mar 20, 2014 by mousaem
Dear all,
I created oracle11gr2 geodatabase using "Create enterprise geodatabase" toolset.
http://resources.arcgis.com/en/help/main/10.1/index.html#//002n0000002v000000
This procedure has created a sde user into oracle with the following privileges/roles:
privileges:
ADMINISTER DATABASE TRIGGER
ALTER ANY INDEX
ALTER SYSTEM
CREATE ANY INDEX
CREATE ANY TRIGGER
CREATE ANY VIEW
CREATE INDEXTYPE
CREATE LIBRARY
CREATE OPERATOR
CREATE PROCEDURE
CREATE PUBLIC SYNONYM
CREATE SEQUENCE
CREATE SESSION
CREATE TABLE
CREATE TRIGGER
CREATE TYPE
CREATE VIEW
DROP ANY INDEX
DROP ANY VIEW
DROP PUBLIC SYNONYM
SELECT ANY TABLE
roles:
SELECT_CATALOG_ROLE
Now, I would like revoke the privileges that are't necessary.   I would like grant sde the priviges necessary to execute typical geodatabase management operation as registrer/unregister feature class, compress, analyze and disconnect user.
Which privileges I must revoke/grant?
In this document (http://resources.arcgis.com/en/help/main/10.1/index.html#//002n0000002v000000) there are the following kinds of users and relative privileges:
- Oracle SDE user privileges for creating an SDE master geodatabase
- Oracle SDE user privileges for upgrading an SDE master geodatabase
- Oracle privileges for creating a user-schema geodatabase
- Oracle privileges for upgrading a user-schema geodatabase
- Common optional privileges (where there are privileges as ALTER SYSTEM and SELECT_CATALOG_ROLE that are necessary for disconnect the users.
but which are the privileges for an sde user in a production system?
Regards
Giuseppe P.
Outcomes
