timlee14
ArcToolbox batch overwrite problem
Discussion created by timlee14 on Mar 19, 2014
I have a tool I created in modelbuilder which works perfectly fine on its own when I run the tool from ArcToolbox. When I use the batch option available when you right click on the tool I have a problem with the output tables being overwritten. For example if I have 5 rows in the batch grid each with unique parameters and output file names the batch function appears to process the output tables all with the same data from the last row. Any help would be much appreciated.
Outcomes
