import arcpy, os # The map with the bookmarks mxd = arcpy.mapping.MapDocument(r"C:\Project\Counties.mxd") # The output feature class to be created - # This feature class will store the bookmarks as features outFC = r'C:\Project\Counties.gdb\Bookmarks' # A template feature class that contains the attribute schema # Including a "Name" field to store the bookmark name template = r'C:\Project\Counties.gdb\Template' if arcpy.Exists(outFC): arcpy.Delete_management(outFC) arcpy.CreateFeatureclass_management(os.path.dirname(outFC), os.path.basename(outFC), "POLYGON", template, spatial_reference=template) cur = arcpy.da.InsertCursor(outFC, ["SHAPE@", "Name"]) array = arcpy.Array() for bkmk in arcpy.mapping.ListBookmarks(mxd): array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMin)) # To close the polygon, add the first point again array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) cur.insertRow([arcpy.Polygon(array), bkmk.name]) array.removeAll()
Solved! Go to Solution.
outFC = r'C:\Project\Bookmarks.shp'
import arcpy, os # The map with the bookmarks mxd = arcpy.mapping.MapDocument(r"C:\Project\Counties.mxd") # The output feature class to be created - # This feature class will store the bookmarks as features outFC = r'C:\Project\Counties_Bookmarks.shp' # A template feature class that contains the attribute schema # Including a "Name" field to store the bookmark name template = r'C:\Project\Counties.gdb\Template' if arcpy.Exists(outFC): arcpy.Delete_management(outFC) arcpy.CreateFeatureclass_management(os.path.dirname(outFC), os.path.basename(outFC), "POLYGON", template, spatial_reference=template) cur = arcpy.da.InsertCursor(outFC, ["SHAPE@", "Name"]) array = arcpy.Array() for bkmk in arcpy.mapping.ListBookmarks(mxd): array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMax)) array.add(arcpy.Point(bkmk.extent.XMax, bkmk.extent.YMin)) # To close the polygon, add the first point again array.add(arcpy.Point(bkmk.extent.XMin, bkmk.extent.YMin)) cur.insertRow([arcpy.Polygon(array), bkmk.name]) array.removeAll()
