I was under the impression that you only needed at least one layer with full editing capabilities turned on in a map; and then you could added other layers that had various, or no, editing abilities turned on.
However if I add layers to my map (that have one layer with full editing turned on) that have no or limited editing turned on, when I go to take maps offline I get the message "A layer does not have the correct editing capabilities".
Can you please elaborate on this? I would really prefer to have some layers fully editable, and other only partially editable (update attributes only etc) in the same map.
Thanks.
