apps
Master Geodatabase & User Schema geodatabase
Discussion created by apps on Mar 17, 2014
Latest reply on Apr 7, 2014 by apps
We have a master geodatabase and 2 user-schema geodatabase (Projects & Survey namely);
From ArcCatalog - direct connect to "project" user-shcema GDB and choose SDE schema from the list.
Question:
Can I create feature class on SDE schema from user-schema connection?
1) If �?? YES then
Who will be the owner of the feature class? and
Where the table is get registered? In Master or User Schema GDB
2) If �?? NO then
We encounter situation here -
Action: -
Try to create new feature class �??  got an error message as below
�??Failed to create feature class.
User-schema owner cannot create/load data in master (SDE) instance�?�
Action �??
Click Ok on the above error message and
Try creating again now able to create without any error message?
Seems something wrong ? isn't?
Thanks in advance for your suggession
Outcomes
