TOOL NOT LICENSED - ERROR 010096
42865
6
03-17-2014 05:06 PM
AaronKeillor
Here's a handy quick fix if anyone is getting the ERROR 01009 warning when they try to use extensions from ArcToolbox (e.g. Spatial Analyst)
___________________________
TOOL NOT LICENSED
Unable to execute the selected tool.
You do not have the necessary license to execute the selected tool.
ERROR 010096: There is no Spatial Analyst currently available or enabled.
In ArcMap 10.1
Select Customize (from the top of the screen)
In the Customize menu, select Extensions
Check the Extension (Spatial Analyst)
* Spatial Analyst is now enabled and you should not get that message any longer (provided you already had it setup correctly in Administrator)
- hopefully that saved a few headaches for future ArcGIS students -
Michelle_Noel
Thank you, that solved my problem first try.
ReubenMolosiwa
Spot on! Still works even on 10.3
FabianAponte
Thank you, absolutely useful for 10.4.
AlexBorisov
10.5, Still works like a charm!
EfthymiosNestoras1
thank you.....
AustinMNole
May 24th, 2022.
STILL WORKS!!!! saved my butt! thanks for sharing your knowledge with us
