Migrate 10.1 to 10.2 via Backup and Restore
692
03-17-2014 03:33 PM
StevenHaslemore
We're setting up a new server and migrating from 10.1 to 10.2 at the same time.
Does anyone have experience with this or know if the backup/ restore approach described here can be applied in this situation?
Cheers!
NidhinKarthikeyan
Occasional Contributor III
Before uninstalling your current ArcGIS Server, make copies of the following files and place them in a stable, secure location. Although you won't be able to directly use these files to restore your services, they preserve a reference of the settings you had. These backups are also useful if the migration is interrupted or postponed.
<ArcGIS Server installation location>\Support\Instance.log
<ArcGIS Server installation location>\server\system\Server.dat
<ArcGIS Server installation location>\server\system\ServerTypes.dat
<ArcGIS Server installation location>\server\user\cfg (all folders and files beneath this location)
C:\inetpub\wwwroot\ArcGIS\Services\web.config (If necessary, adapt this path to your own web server's root location and your ArcGIS Server instance name.)
NidhinKarthikeyan
