wtgeographer
Populate parameter[2] and parameter[3] from field
Discussion created by wtgeographer on Mar 17, 2014
I am populating parameter[2] using validation code provided by esri. How can I modify this code repeat for parameter[3] what was done for parameter[2]. Hope this makes sense?
import arcpy
class ToolValidator(object):
  """Class for validating a tool's parameter values and controlling
  the behavior of the tool's dialog."""
  def __init__(self):
    """Setup arcpy and the list of tool parameters."""
    self.params = arcpy.GetParameterInfo()
    self.fcfield = (None, None)
  def initializeParameters(self):
    """Refine the properties of a tool's parameters.  This method is
    called when the tool is opened."""
    return
  def updateParameters(self):
    """Modify the values and properties of parameters before internal
    validation is performed.  This method is called whenever a parmater
    has been changed."""
    if self.params[0].value and self.params[1].value:
      fc, col = str(self.params[0].value), str(self.params[1].value)
      if self.fcfield != (fc, col):
        self.fcfield = (fc, col)
        self.params[2].filter.list = [str(val) for val in
                                        sorted(
                                          set(
                                            row.getValue(col)
                                            for row in arcpy.SearchCursor(fc, None, None,
        col)
        if self.params[2].value not in self.params[2].filter.list:
          self.params[2].value = self.params[2].filter.list[0]
  def updateMessages(self):
    """Modify the messages created by internal validation for each tool
    parameter.  This method is called after internal validation."""
Outcomes
