Rotating Symbols
907
03-17-2014 09:46 AM
MichaelKohler1
Hi, I have some point symbols that I rotate because the data view has a specific rotation.  But when I rotate the symbols, they also rotate in the legend.  Is there a way to rotate the symbols on the map, but have a zero rotation in the legend?
Michael Kohler
JoshuaChisholm
Occasional Contributor III
Hello Michael,
When I set rotation for a symbol, it does not change the rotation in the legend. I set rotation by Layer Properties > Symbology tab > Advanced > Rotation. (I'm using 10.1)
MichaelKohler1
That worked, thanks.
RobertBorchert
Frequent Contributor III
You can also adjust a setting on the Legend to not change when symbols change.
However, the previous recommendation rotate based on attribute is the better option.  That is what I use as well.
