I got the Problem and Also Solution to it.The Problem was, when we are adding more than 2-3 Values to renderer the Request to refresh or add the layer was getting failed due to content length of the request.so to solve this problem i used proxy page.Below is my solution: After applying renderer while adding the layer or refreshing it please set esri.config.defaults.io.alwaysUseProxy = true; Once you added the layer or refreshed you can set proxy to false again.Working Sample:[HTML]<!DOCTYPE html><html><head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Unique Value Renderer</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/LayerDrawingOptions", "esri/InfoTemplate", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/UniqueValueRenderer", "dojo/parser", "dojo/_base/Color", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function ( Map, FeatureLayer, ArcGISDynamicMapServiceLayer, LayerDrawingOptions, InfoTemplate, SimpleLineSymbol, SimpleFillSymbol, UniqueValueRenderer, parser, Color ) { parser.parse(); esri.config.defaults.io.proxyUrl = "proxy.ashx"; map = new Map("map", { basemap: "streets", center: [-95.625, 39.243], zoom: 4, slider: false }); map.on("load", addDynamicLayer); function addDynamicLayer() { // add US States as a dynamic map service layer var urlDyn = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer"; var usaLayer = new ArcGISDynamicMapServiceLayer(urlDyn, { id: "us_states", visible: true }); usaLayer.setVisibleLayers([3]); var defaultSymbol = new SimpleFillSymbol().setColor(new Color([255, 255, 255, 0.2])); //create renderer var renderer = new UniqueValueRenderer(defaultSymbol, "SUB_REGION"); renderer.addValue("Pacific", new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5]))); renderer.addValue("Mountain", new SimpleFillSymbol().setColor(new Color([0, 255, 0, 0.5]))); renderer.addValue("New England", new SimpleFillSymbol().setColor(new Color([0, 0, 255, 0.5]))); renderer.addValue("South Atlantic", new SimpleFillSymbol().setColor(new Color([255, 0, 255, 0.5]))); renderer.addValue("Middle Atlantic", new SimpleFillSymbol().setColor(new Color([255, 255, 255, 0.75]))); renderer.addValue("East North Central", new SimpleFillSymbol().setColor(new Color([0, 255, 255, 0.5]))); renderer.addValue("West North Central", new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5]))); renderer.addValue("East South Central", new SimpleFillSymbol().setColor(new Color([127, 127, 127, 0.5]))); renderer.addValue("West South Central", new SimpleFillSymbol().setColor(new Color([0, 0, 0, 0.5]))); var optionsArray = []; var drawingOptions = new LayerDrawingOptions(); drawingOptions.renderer = renderer; // set the drawing options for the relevant layer // optionsArray index corresponds to layer index in the map service optionsArray[3] = drawingOptions; usaLayer.setLayerDrawingOptions(optionsArray); //After applying renderer while adding the layer or refreshing it please set //esri.config.defaults.io.alwaysUseProxy = true; //Once you added the layer or refreshed you can set proxy to false again. esri.config.defaults.io.alwaysUseProxy = true; map.addLayer(usaLayer); esri.config.defaults.io.alwaysUseProxy = false; } }); </script></head><body> <div id="map"> </div></body></html>[/HTML]
