thebillcarr
Cannot zoom to graphic
Discussion created by thebillcarr on Mar 11, 2014
Latest reply on Mar 13, 2014 by kenbuja
I've been tackling this problem all day and help would surely be appreciated. I'm new to JS and I'm attempting to zoom to a graphic selected from a  FindTask. The graphic shows up on the correct point but I can't for the life of me get it to zoom to a point feature. Thanks
This is slapped together from various samples and examples. JS 3.8.
 //create find parameters
        findParams = new esri.tasks.FindParameters();
        findParams.returnGeometry = true;
        findParams.layerIds = [0];
        findParams.searchFields = ["OBJECTID"];
        var sr = new esri.SpatialReference({wkid:102100});
        findParams.outSpatialReference = sr;
      //set the search text to find parameters
      function execute(searchText) {
        findParams.searchText = searchText;
        findTask.execute(findParams, showResults);
      //symbology for graphics
      function showResults(results) {
        var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10);
      //find results return an array of findResult.
        map.graphics.clear();
        var dataForGrid = [];
        //Build an array of attribute information and add each found graphic to the map
        dojo.forEach(results, function(result) {
          var graphic = result.feature;
          if (graphic.geometry.x === 0 || graphic.geometry.y === 0) {
            console.warn(graphic.geometry.toJson());
            return;
          switch (graphic.geometry.type) {
            case "point":
              graphic.setSymbol(markerSymbol);
              break;
          //add graphics to map
          map.graphics.add(graphic);
         map.setExtent(map.graphic[0].feature.geometry.getExtent());
        //THIS IS WHERE EVERYTHING GOES WRONG.....
        if (map.graphics.graphic.length > 1) {
          var graExtent = esri.graphicsExtent(map.graphics.graphics);
        else if (map.graphics.graphic.count == 1) {
      dojo.addOnLoad(init);
Outcomes
