Roles in ArcGIS Online
2539
03-10-2014 07:30 AM
AidanMallamo
I added a viewer only role today and it appears to correctly have view only/no edit privileges on the browser version of ArcGIS Online, but on the IOS app, the user can still edit the feature service.
Is the role update not effective on the mobile apps? Has anyone else seen this?
RussRoberts
Esri Notable Contributor
The apps like Collector and ArcGIS for iOS/Android currently do not have full support for the custom roles. You can disable editing on the layers in the web map to work around this issue.
Cheers
Russ
RussRoberts
Cheers
Russ
AidanMallamo
Cheers
Russ
Thanks. This probably should be identified somewhere until it's changed.
