joeqiu
Sample Application Error
Discussion created by joeqiu on Mar 10, 2014
Latest reply on Mar 26, 2014 by MBranscomb-esristaff
I am new to ArcGIS. I was trying to run the sample appliction, but I got the error below on my computer. I am using Windows 7 Enterprise with Service Pack 1, 64 bit OS and 8GB RAM on VMware. I really appreciate if someone can point out the problem.
Sample: LocalMap
Error: Failed to create Accelerated Display. Please check the display hardware and drivers meet the minimum requirements.
Stack Trace:
   at ESRI.ArcGIS.Client.NativeMap..ctor(INativeMapOwner map, Single dpi)
   at ESRI.ArcGIS.Client.DrawingSurface.CreateRenderSurface(INativeMapOwner owner)
   at ESRI.ArcGIS.Client.Map.OnApplyTemplate()
   at System.Windows.FrameworkElement.ApplyTemplate()
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Sample: LocalMap
Error: Object reference not set to an instance of an object.
Stack Trace:
   at ESRI.ArcGIS.Client.DrawingSurface.SetSize(Int32 width, Int32 height)
   at System.Windows.Threading.DispatcherTimer.FireTick(Object unused)
Outcomes
