Solved! Go to Solution.
Dear colleagues,
I have the following problem I cannot solve. I have house transaction data and catchment boundaries that have been spatially joined, so that I can identify, in which catchment area a transaction took place from the attribute table. I'd like to find the closest matching pairs of transactions located on either side of the boundary in the nearest proximity to each other.
To do so, I wanted to calculate Euclidean distances between the transactions on either side of the boundary and identify the nearest ones. I checked all the tools available in ArcGIS, but they don't seem to allow me to do so. There is a tool that allow me to find the nearest "neighbour" though, but I'd like it to be the nearest "neighbour" located on the other side of the boundary.
I'm new to programming but learned a few bits in python over the last couple of days.
Would greatly appreciate your help in guiding me how to go about this issue and if it's plausible at all.
I'm using ArcGIS 10.0.
Many thanks in anticipation,
Best wishes,
Le
Dear colleagues,
Best wishes,
Le
Thank you for your prompt reply!
The process you explained step by step is exactly what I've been looking for. Thanks!
I' ve been trying to implement it but unfortunately I'm stuck in a place in which I'm supposed to join the point distance output table input_FID with the ObjectID from the original points. The problem is that the geometry calculation field is disabled.
Im using projected coordinate system so I don't know why i cannot proceed.
Any ideas?
Many thanks.
Le
Thanks for that. I got around it eventually and was able to calculate it, as I wanted to. It's been a very educative week and learned a few useful bits that should help in future.
What I wanted to ask however is whether there is an alternative way, I could consider when working with a larger dataset? This operation already took a while and I have a quite significantly larger file to be processed.
Perhaps you know how could I set the near tool up, so that it searches for the points located in the nearcatchment only?
Thanks.
