USForestServiceAdmin
Toggle on/off filters using filter template
Discussion created by USForestServiceAdmin on Mar 7, 2014
I have created a filter web application displaying a map service of buildings.  The extent is nation-wide.  My source layer has 96 attributes in it, and in my filter web application, I have defined 18 filters.  It works very well, however, I would like to be able to turn on/off specific filters at will to return different results depending on the filters I choose to use.  From what I can tell, the filter template available when you share your web map application does not allow you to turn a filter on or off, it's a take it all or leave it kind of a thing.  So my question is, is there a way to turn a filter on/off using the filter template, or would I need to custom code something like that?
Thanks in advance!
Outcomes
