Map.CenterAndZoom Issue
3109
5
03-06-2014 02:01 AM
NikitaWachstaub
Good day,
I cannot get a center and zooming funktion in my JS-Viewer. Hier is the code:
function DrawPointAndZoom() {
        try {
            var mylat = 29.818008;
            var mylong = 5.423178;
            var latLongPoint = new esri.geometry.Point(mylat, mylong, new esri.SpatialReference({ wkid: 4326 }));
            var mercator = esri.geometry.geographicToWebMercator(latLongPoint);
            map.centerAndZoom(mercator, 10)
        catch (err) {
            alert(err);
I get an error:    TypeError: map.centerAndZoom is not a function
What can be the problem?
NikitaWachstaub
KenBuja
MVP Esteemed Contributor
Can you post your code or a working sample at JSBin that shows the problem?
NikitaWachstaub
The problem is already solved)
JacquelineKovarik
New Contributor III
Can you please post the solution here?
KeithGanzenmuller
Occasional Contributor II
What was the solution?
