Where to Download ArcObjects C++ SDK?
3416
03-04-2014 12:59 PM
RichardMorey
Hi --
I have just signed up as a developer and I'm interested in learning more about developing apps for ArcGIS. However, my programming language of choice is Delphi/Pascal and so I'd like to download the C++ SDKs. Can someone point me to a URL where these are available? I've found the Android, iOS, etc. on the main developers page but not the C++ files.
Rich
RichardWatson
If you are looking for the ArcGIS Runtime SDK for C++ then check this out:
https://developers.arcgis.com/qt/
If you are looking for ArcObjects then:
ESRI requires a customer login in order to access them here:
https://customers.esri.com
ArcGIS 10.2.1 for Desktop includes the ArcObjects SDKs as does ArcGIS 10.2.1 for Server.
RichardMorey
Hey --
Thanks. I downloaded the files from the /QT/  link. I also downloaded and installed a 60 demo trail of ArcGIS Desktop. Does the demo include the SDK? If so, can you tell me where? I didn't see any obvious folders in the install directory.
Rich
RichardWatson
I doubt it.
There is usually a file named something like ESRI.exe that you run with the normal ArcMap ISO image.
When you run that then you will see all the pieces that you can install.
