How do I Update a Table via a FeatureService?
1038
03-04-2014 06:31 AM
KeithFraley1
I have my feature service all set up, I have my table served up in that feature service.  I can access via the rest explorer and do the update manually via "updateFeature" url.  what am I missing or is there a better way?
What is the best way to do this in javascript.  I keep getting a 405 error when I try and execute using dojo.xhrPost
var xhrArgs = {
      url: "http://url/FeatureServer/3/updateFeatures",
      postData: attributes),
      handleAs: "json",
      load: function(data){
        console.log("Message posted.");
      error: function(error){
    console.log("Message being posted.");
    var deferred = dojo.xhrPost(xhrArgs);
JonathanUihlein
Hi Keith!
Some documentation here:
https://developers.arcgis.com/javascript/jshelp/inside_feature_layers.html
The tutorial links at the bottom of that document are what you are looking for.
JakeSkinner
Esri Esteemed Contributor
Hi Keith,
I've never used dojo.xhrPost, but below is an example using XMLHttpRequest:
function addFeatures() {
    addFeaturesUrl = 'http://server/arcgis/rest/services/ClosedRoadsAddress/FeatureServer/2/addFeatures?features='
    addAttributesUrl1 = '[{"attributes":{"Address":"'100 Main St'"}}]'
    var obj1 = encodeURIComponent(addAttributesUrl1);
    var theUrl1 = addFeaturesUrl + obj1;
    var xmlHttp = null;
    xmlHttp = new XMLHttpRequest();
    xmlHttp.open( "POST", theUrl1, false );
    xmlHttp.send( null );
saurabhgupta2
Hi jake
I am trying to modify one attribute in my feature service layer  in arcgis 10.2.2  using a json object .
Can u help me briefing out how to make that request . Can i do it without using any of the arcgis api .
regards
saurabh
JakeSkinner
Hi Saurabh,
Yes, you can do this without the ArcGIS API for JavaScript.  Below is an example:
//json
var jsonObject = '{ "employees" : [' +
'{ "firstName":"John" , "lastName":"Doe" }]}';
//parse json
var obj = JSON.parse(jsonObject);
var lastName = obj.employees[0].lastName;
//update URL for feature service
var updateFeaturesUrl = 'http://server/arcgis/rest/services/Employees/FeatureServer/0/updateFeatures?features=
var updateAttributesUrl1 = '[{"attributes":{"OBJECTID":1,"NAME":"' + lastName + '"}}]'
var obj1 = encodeURIComponent(updateAttributesUrl1);
var theUrl1 = updateFeaturesUrl + obj1;
var xmlHttp = null;
