Tonyalmeida
Select by location based on selected features
Discussion created by Tonyalmeida on Feb 28, 2014
Latest reply on Mar 3, 2014 by Tonyalmeida
I am trying to do a select by location, I am trying to do a selection by location on just the parcel that the newly create point is created on, then do a spatial join to then do a search cursor on that one parcel record to grab and populate the attributes i need.
The tool's code is suppose to create a point, populate the x,y & AddressID fields and populate the "add_fields" from the Parcels.
Here my tool's code i have, but it does nothing so i am guess my select by location is not correct. I would supper appreciate help with this code.
import arcpy
import pythonaddins
import os
import time
from arcpy import env
class Timer:
    def __enter__(self):
        self.start = time.clock()
        return self
    def __exit__(self, *args):
        self.end = time.clock()
        self.interval = self.end - self.start
class Add_points(object):
    """Implementation for AddPoints_addin.Add_points (Tool)"""
    def __init__(self):
        self.enabled = True
        self.cursor = 3 # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
    def onMouseDownMap(self, x, y, button, shift):
        ###### Creats point and populates fields x,y & AddressID
        fcTarget = "TonyTwoWay.DBO.TT"
        workspace = r"C:\Users\talmeida\AppData\Roaming\ESRI\Desktop10.1\ArcCatalog\Connection to dsd15_sqlexpress.sde"
        #arcpy.ChangeVersion_management('TonyTwoWay.DBO.TT','TRANSACTIONAL','dbo.DEFAULT', "")
        # Start an edit session. Must provide the worksapce.
        edit = arcpy.da.Editor(workspace)
        # Edit session is started without an undo/redo stack for versioned data
        #  (for second argument, use False for unversioned data)
        edit.startEditing(True)
        # Start an edit operation
        edit.startOperation()
        CC_list = []
        with arcpy.da.SearchCursor(fcTarget, ["AddressID"]) as cursor:
            for row in cursor:
                try:
                    if "CC" in row[0]:
                        CC_list.append(int(row[0].strip("CC")))
                except TypeError:
                    pass
        del cursor
        t = Timer()
        with t:
             CC_list.sort()
             AddressID = CC_list[-1] + 1
             AddressID = 'CC' + str(AddressID)
             row_values = [(x, y, (x, y), AddressID)]
             cursor = arcpy.da.InsertCursor(fcTarget, ["X_Coord", "Y_Coord", "SHAPE@XY", "ADDRESSID"])
             for row in row_values:
                 cursor.insertRow(row)
             del cursor
             # Stop the edit operation.
             edit.stopOperation()
             # Stop the edit session and save the changes
             edit.stopEditing(True)
        timetest = "completed in %.02f secs." % (t.interval)
        print timetest
        Parcel = "testParcelsAdmit"
        add_fields = ["ACCOUNT","SiteNum","OwnerName","SiteAddres","SiteNumSfx","SiteStreet","predir","StreetType","SubName"]
        Parcel_lyr = arcpy.MakeFeatureLayer_management(Parcel, "Parcel lyr")
        entries = int(arcpy.GetCount_management(fcTarget).getOutput(0))
        for i in xrange(entries):
            pt_lyr = arcpy.MakeFeatureLayer_management(fcTarget, "points_layer", "\"OBJECTID\"={}".format(str(i)))
            arcpy.SelectLayerByLocation_management(Parcel_lyr, "INTERSECT", pt_lyr, "", "NEW_SELECTION")
        # fix args
        if not isinstance(add_fields, list):
            # from script tool
            add_fields = add_fields.split(';')
        # do not need this scratch file
        fcOutput = r'in_memory\temp_join'
        arcpy.SpatialJoin_analysis(Parcel_lyr, fcTarget,fcOutput, 'JOIN_ONE_TO_MANY')
        # grab oid field from points
        oid_t = arcpy.Describe(fcTarget).OIDFieldName
        # Add JOIN_FID to first item in field list
        add_fields.insert(0, 'JOIN_FID')
        # Create dictionary
        with arcpy.da.SearchCursor(fcOutput, add_fields) as rows:
            join_dict = {r[0]:[r[i] for i in range(1,len(add_fields))] for r in rows}
        # Now update the new target
        curW = arcpy.UpdateCursor(fcTarget)
        for row in curW:
            t_oid = row.getValue(oid_t)
            if t_oid in join_dict:
                for f in add_fields:
                    row.setValue(f, join_dict[t_oid][add_fields.index(f)])
            curW.updateRow(row)
        del row, curW
        arcpy.AddMessage('Updated all records sucussefully')
        pass
Outcomes
