File "\\spatialfiles.bcgov\Work\em\vic\mtb\Local\scripts\python\overlap_report\mike_mac\Test_Scripts\Test_Clip_Placier_Poly.py", line 11, in <module>
arcpy.Clip_analysis(r"Database Connections\ABC.sde\SPATIAL.GRID_POLY",r"W:\Shapefiles\Test_Extent.shp",r"W:\Geodatabases\Clipped_FeatureClasses.gdb\OUTPUT")
File "E:\sw_nt\ArcGIS\Desktop10.1\arcpy\arcpy\analysis.py", line 56, in Clip
raise e
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
The table was not found.
The table was not found. [OUTPUT]
Unable to create logfile system tables. User perhaps lacks permissions or resources to create tables [ORA-01031: insufficient privileges
Failed to execute (Clip).
