The map or layer has been destroyed or recyled
3666
6
02-23-2014 05:51 AM
teamIgal
New Contributor III
I have a problem when the app restores after the map activity has been destroyed by the system.
The system calles OnDestroy on it's own, which is fine, but then, when i open the app back, everything restores (the app calles OnCreate again) except for the mapView Object.
When i try to add layers to the mapView i get the following message:
"The map or layer has been destroyed or recyled"
Does anybody had the same problem?
Any clues how to fix this?
Thank,
Team Igal
teamIgal
New Contributor III
also, i tryed to add the mapView from code,
and in the OnCreate i even set
mMapView = null
mMapView = new MapView(...
and still i get the same error, and i can't see the map.
JasonKnisley
That's not an error that I've seen before. By chance, are you overriding onDestroy and not calling super.onDestroy() at the end of the method?
teamIgal
New Contributor III
I am overriding onDestroy, but i am calling super.onDestroy() in the end of the method.
JasonKnisley
If you're still wrestling with this issue and want someone else to test it out, feel free to PM me. I can give you my email address and if your able to email your code to me then I can replicate it on one of my devices and see if I can figure out what the problem might be.
teamIgal
New Contributor III
Thank you for the help! Unfortunetly i can't send the code.
But i realized that the map is never being initialized after i resume back.
The listener of the status changed is not being called
KunalMehta
Did you find a resolution to this? I am facing the same issue with ArcGIS Android SDK 10.2.3.
