RudinA
Gemeotric Network Flow Direction and Replication Question
Discussion created by RudinA on Feb 20, 2014
Latest reply on May 1, 2014 by RudinA
Are the flow directions of edges in a geometric network supposed to come over when sync'd through a replica?  The flow direction I set in the parent geodatabase did not appear in the child geodatabase after my one-way replica was sync'd.  The feature comes over and it looks like the network connectivity is intact, so its just the network flow that's not updating.  In the parent system if I create a feature and then set the network flow 'with digitized direction' and then do a sync, the replicated feature has indeterminate flow.  Wasn't sure if this was a bug or by design.
Here's my setup:
  • Desktop 10.2 (Not 10.2.1)
  • SDE 10.2 on Oracle 11gR2 database
  • Replicating to 10.2 file geodatabase
  • Geometric network consists of one point and one line feature class.
  • Line feature class is a complex edge
  • One-way replica- Parent to child
  • Replica Access Type set to Full
  • Tried replication with and without archiving and get same result.
Thanks for any help you can provide,
Andrew
Outcomes
