megie91
Points to Line coordinate system issue in ModelBulider
Discussion created by megie91 on Feb 17, 2014
Latest reply on Feb 17, 2014 by dhoneycutt-esristaff
I'm using the Points to Line tool in ModelBuilder. I have set a model parameter for the Coordinates System and adjusted the Model Properties to use the Coordinates System parameter for the output coordinates and set the tool properties to use the Coordinates System parameter for the output coordinates, however the resulting line shapefile has no defined coordinate system.  Other output shapefiles in the model are taking on the defined Coordinate System, but the Points to Line tool will not.  I have also tried to set the Output Coordinate System to be the same as the input points shapefile (which coincidentally exports with the correct coordinate system) with no success.
Does anyone know of a work around or code adjustment to get this to work properly?
Outcomes
