XY coordinate question/help....please!!!
732
9
02-17-2014 04:48 AM
ELTerrell
New Contributor III
I'm trying to add a spread sheet to my map with xy coordinates.  I have 195 points I want to plot of polling sites in a county.  In the spread sheet I have the ID column (polling site), the X and Y columns.  When I go to add data it tells me I do not have an object ID.  I can get the points to map but can only see them if I "zoom to layer".  At that point I can't see any of the other layers that should be visible.
After reading a few threads it looks like I can either attach this to my precinct layer/shape file....or add it seperately.  However, I haven't been able to make either work.
Can anyone help me?  Please & thank you.
TimWitt
No problem, don't forget to mark the answer by hitting the grey checkmark next to it 🙂
TimWitt
You need to make sure that when you add your XY data to choose the same coordinate system as your other layers.
ELTerrell
New Contributor III
Thank you.  So how do  I make sure the coordinate system is the same?
TimWitt
Right click one of your other layers and choose properties. There go to the Source tab and scroll down to Coordinate system.
ELTerrell
New Contributor III
Ok....they were all the same: GCS_North_American_1983.
What else should I check?
TimWitt
Is this the coordinate system you chose when adding your XY data?
If not use the WGS84 system, that usually works.
Geographic Coordinate Systems -> World and there choose WGS 1984
ELTerrell
New Contributor III
Yes, that's the one I chose (actually it populated automatically).
I don't see WGS84 anywhere.  Where should I be looking for that?
TimWitt
ELTerrell
New Contributor III
Boom!!! That worked!  Thanks so much for your help!
TimWitt
